12 years agoPin Assignment for SSRAM on Stratixiv gx 230
Hello everyone,
I am working on Stratixiv with SSRAM component. But I don't know where I can find the pin assignment for SSRAM to import. Does anybody can suggest to me ? Thank you very much !4 Replies
It's described in the reference manual and most likely defined in the pin assigments of example projects shipped with the board.
--- Quote Start --- It's described in the reference manual and most likely defined in the pin assigments of example projects shipped with the board. --- Quote End --- Hi FvM, I though Altera supports the pin assignment file for Stratixiv like DE2 because I also hope to get the pin assignment file for all component on the board. If I do it manually, it will take me a long time. If I can't find a available assignment, maybe I will assign manually. Thank you very much ! - Altera_Forum
If you are talking about a development kit that has a Stratix IV and a SSRAM, then with the kit you should have a DVD (or can find its contents as a downloadable file) that contains a "golden" project. This project has all the I/O assignments made for you.
Hi Daixiwen,
I found all I/O assignments at golden_top project as you mentioned. Thank you very much.
