SMude
5 years agoPCN Clarification
Hi Team,
Hope you are doing good.
Could you please suggest if the software updates affect the application of 10M08DAU324I7G.
- Our End Customer designs were compiled using a??Quartus Prime V17.0.1 Build 598 06/07/2017 Lite Editiona?? and a??Quartus Prime V17.1.0 Build 590 10/25/2017 Lite Editiona. Are any V17.x software tools affected by the issue described in ADV2110 / PCN 118143- 00 (15-MAR-2021).
- One design uses a ROM: 1-PORT component created using the MegaWizard Plug-In Manager which is implemented (according to the fitter report) as altsyncram:altsyncram_component and uses M9K blocks. This is preloaded in the FPGA .POF using a .MIF file (quartus_cdb %1 --update_mif, and quartus_asm %1). Is this ROM module affected by the issue?
- Does this issue affect designs that contains SignalTap auto-generated memory blocks?
- Does this issue affect design that contain max10_adc1_modular_adc design blocks, which auto-generate altsyncram used as FIFOram?
Looking to hear from you at the earliest
1 Reply
- YuanLi_S_Intel
From the PCN, it affects Intel Quartus Standard Edition. Since you are using Lite edition, it is not impacted.
Thank You.
Bruce
