11 years agoPCISIG Compliance of Stratix V GX FPGA Development Board ??
Can anyone say if the Stratix V GX FPGA development board passes the PCISIG compliance tests for Gen3 ? Or has been to a PCISIG "plugfest". I ran the board configured as Gen3 X1 , which worked...
11 years agoHere is an answer ...
http://www.alterawiki.com/wiki/pci_sig_gen3_x8_merged_design_-_stratix_v I came across this in a search I guess .. It is a design with 3 compliance based functions that I assume is the same PFGA design used to pass PCISIG compliance. I have build the design and committed to FLASH and will run the compliance tests on it ... any ideas on how to get to EP loopback mode ? Interestingly the 3 compliance modes are DIP Switch selected .... OR if you only have the FPGA, clocks and power, there is a "probe" function allowing the switch inputs to be forced as if there was a virtual switch ... neat ! Thanks, Bob.
