13 years agoPCIe on Stratix IV
Hello, I am an altera newbie and am currently working on getting the PCIe system running on DE4.The version of quartus I am using is 10.0 and the SOPC builder fails every time I try to build th...
13 years ago --- Quote Start --- Newer version of the Quartus(12.0) is installed now and I am able to build the PCIe system. --- Quote End --- OK. I think that 13.x has better support for PCIe now ... but I have not looked at that version yet. --- Quote Start --- But I am not able to communicate with the board. I am working on a linux machine, and lspci command shows no track of the altera board being connected. I noticed in your pdf that sometimes wthout the reconfiguration reset logic, the device would never negotiate with a X4 width. The design currently under test is without reconfiguration reset logic and withX4 width. Would this be a problem? --- Quote End --- Download one of the original example designs that comes with the kit. If that design shows up ok, then you know that your problem is related to your current design. Cheers, Dave
