12 years agoPCIe Hard IP returning stale data for Cyclone IV
I have recently ported a PCIe endpoint design working on Arria V to Cyclone IV , ( Transciever Starter Kit ) . I need to go back but don't believe I see the problem on Arria V which is a very ...
12 years agoHi Peter,
From my experience, geetting the Arria V Starter Kit board going was a fair amount of work but it should not have been. I was on a Linux system and had to learn Linux device driver by taking various examples and comming up with something that worked. On the Windows environemnt I would think it should be easier since with the Juno driver. I'm not sure about the 79 devices unless they actually exist. I did some work on a PC and found it useful using some of the existing tools to enumerate the slots after POST /BIOS which will say that your card has trained and is seen in the slot ... I had some trouble with various slots even at Gen1 due to slot width. I did run the sample application doing DMA and it measures write / read performance ... I can check whatthat was. It would have been the sample DMA application. Let me try to digest your points and get back to you. Bob.
