CHung
6 years agoPCIe hard IP example design generation fail
Hi I generate example design of Stratix PCIe hard IP and get error message as following figure. Could you please fix the problem? PS. I'm using Quartus v18.1.2 and v19.1.
SengKok_L_Intel
6 years agoHi,
I'm using v19.1 to generate the Avalon-MM intel Startix 10 Hard IP+ example design by using the default setting, but I can't see the same error.
Questions:
- How do you configure the IP? Does using default settings also having the same issue?
- What is the OPN (Device's full name)?
Regards -SK
CHung
6 years agoHi SK,
- I got the same errors either using default setting or selecting gen3x8 configuration.
2. The device full name is 1SM21CHU1F53E1VG.
