Maxime_Kanawasaki
1 year agoPCIe Example Design for Arrow EAGLE Board
Hello !! I'm using Arrow Agilex-5 EAGLE Board with Device A5ED065BB32AE4SR0 with Q25.1 I've generated IP Core Example Design for Development Kit selected NONE. GTS AXI Streaming Intel FPGA IP ...
jc_ddc
1 year agoI am experiencing the same issue. I was able to simulate the design example using Questa, but was unable to run in on hardware.
I ran into issues mapping the two reset pins. There is no indication on which pin "p0_pin_perst_n_1_i_reset_n" needs to be connected to.
I believe you're correct in changing the IO PLL Reference Clock to 25 MHz since this is what the Eagle board provides.
