17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years agoHi, Sophie,
I didn't know that file (s2gxpcie.pdf), it is very useful. I connected the rx_clk and tx_clk to PIN_M27 and PIN_F28 respectively. The source_clock is now connected to PIN_A20. And I created a input pin, called reset_phy (PIN_AM22). It is connected with the output pin called enet_resetn (PIN_H31). But it didn't work yet. I will use the Signal Tap to see what is happen with tx_clk, rx_clk, rx_d[7..0] and tx_d[7..0].
