17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years agoSorry for the delay, I promised that it would post the project when the DDR2 was working.
I still have problems with the TSE module... I think that is the timing constraints or there's something wrong with design... I don't know how to correctly use the Time Quest :(. I receive this in the Simple Socket Server: --- Quote Start --- nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 2, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) =============== Software License Reminder ================ This software project uses an unlicensed version of the NicheStack TCP/IP Network Stack - Nios II Edition. If you want to ship resulting object code in your product, you must purchase a license for this software from Altera. For information go to: "http://www.altera.com/nichestack" ===================================================== InterNiche Portable TCP/IP, v3.0 Copyright 1996-203 by InterNiche Technologies. All rights reserved. prep_tse_mac Could not locate flash sector with MAC address. Static IP Address is 192.168.0.200 prepared 1 interface, initializing... [tse_mac_init] SGDMA desc memory cleared [phyID] 0x12 141 cc2 [netif_tse] found Marvell 88E1111 PHY Speed is 1000 is 0 Full Duplex is 1 OK, x=1, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created IP address of et1 : 192.168.0.200 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) --- Quote End --- I never saw the TX led blinking :confused:, and why I receive this: " Speed is 1000 is 0 Full Duplex is 1".
