prateekmohan
5 years agoPCIe Avalon-MM to DDR Write and Read
I am looking at methods to write/read from DDR from my host system through the PCIe Hard IP block.
I have looked at some examples for Qsys projects using the PCIe Hard IP block and I under...
Deshi_Intel
5 years agoHi,
Pls see my reply below.
- Yes, you need to initiate external memory interface IP to use DDR3 or DDR4
- For the different clock frequency connection issue between PCIe Avalon MM Bar and DDR3 Avalon MM interface - I think you can use "Avalon MM clock crossing bridge" IP in platform designer to handle the different clock domain crossing
dlim
