13 years agoOutput signal of IRM-V538N7/TR1 (Infrared module of DE2-115)
Hello, I have a DE2-115 dev board which has an IR-receiver on board. I would like to make it work within a VHDL-written system. But there I encountered a problem. As far as I can see the ...
13 years agoI can, here you go. This is for the remote supplied with the DE2-115 Board.
You can also find these values by means of the DE2-115 control panel.
when std_logic_vector'(x"0F") =>
Btn_A <= '1';
when std_logic_vector'(x"13") =>
Btn_B <= '1';
when std_logic_vector'(x"10") =>
Btn_C <= '1';
when std_logic_vector'(x"12") =>
Btn_power <= '1';
when std_logic_vector'(x"01") =>
Btn_1 <= '1';
when std_logic_vector'(x"02") =>
Btn_2 <= '1';
when std_logic_vector'(x"03") =>
Btn_3 <= '1';
when std_logic_vector'(x"04") =>
Btn_4 <= '1';
when std_logic_vector'(x"05") =>
Btn_5 <= '1';
when std_logic_vector'(x"06") =>
Btn_6 <= '1';
when std_logic_vector'(x"07") =>
Btn_7 <= '1';
when std_logic_vector'(x"08") =>
Btn_8 <= '1';
when std_logic_vector'(x"09") =>
Btn_9 <= '1';
when std_logic_vector'(x"00") =>
Btn_0 <= '1';
when std_logic_vector'(x"1A") =>
Btn_chnl_up <= '1';
when std_logic_vector'(x"1E") =>
Btn_chnl_down <= '1';
when std_logic_vector'(x"1B") =>
Btn_vlm_up <= '1';
when std_logic_vector'(x"1F") =>
Btn_vlm_down <= '1';
when std_logic_vector'(x"0C") =>
Btn_mute <= '1';
when std_logic_vector'(x"11") =>
Btn_menu <= '1';
when std_logic_vector'(x"17") =>
Btn_return <= '1';
when std_logic_vector'(x"16") =>
Btn_play <= '1';
when std_logic_vector'(x"14") =>
Btn_left <= '1';
when std_logic_vector'(x"18") =>
Btn_right <= '1';
when others =>
--do nothing
And for the people out there who are to lazy to read datasheets, I also give you the custom code of the remote: x"68B6" You'll just have to do the codewriting yourself.
