Our host PC can't discover Stratix 10 MX devkit as a PCIe device, even after a successful configuration and a proper installation of Linux driver.
- 6 years ago
Hi Hsuh,
The initial post was mention about AN811 but now become AN881. So I just curious if you already tested the AN881.
- For the AN881 example design, it is using v19.1 pro. Did you run the Post-processing Script (section 2.2) if you re-generate the Platform designer or upgrade the design?
- Is your MX board consist of the following device? 1SM21BHU2F53E1VG
- Are you using the driver that comes with the AN881 example design?
- Do you have a chance to validate it on the CentOS 7.0 and see if there is any OS dependency?
- Could you please capture ltssmstate[5:0], currentspeed[1:0], lane_act[4:0] and link_up signal from Signaltap? This can help to confirm if the link training is up correctly.
Regards -SK
As long as the slot of the Host PC can support Gen3X16, then it should be able to at least detect the FPGA’s PCIe interface (provided it can link up correctly). I don’t aware if any BIOS settings may impact it. The same reference design was tested here and which is working fine in one of our PC. You may try the same with different PC/server/slots to isolate if there is any dependency, and then you can also compare the BIOS setting for any difference.
Yes, please refer to the script.zip for the post-processing script that comes with the reference design. You need to run it to meet the requirement.
Regards -SK
