HSuh01
6 years agoOur host PC can't discover Stratix 10 MX devkit as a PCIe device, even after a successful configuration and a proper installation of Linux driver.
We are trying to use Intel's DMA IP and PCIe Hard IP+ to communicate to the HBM memory. So far, we've tested AN881 design, AVMM PCIe Hard IP+ example design, and the PCIe golden design that comes wit...
- 6 years ago
Hi Hsuh,
The initial post was mention about AN811 but now become AN881. So I just curious if you already tested the AN881.
- For the AN881 example design, it is using v19.1 pro. Did you run the Post-processing Script (section 2.2) if you re-generate the Platform designer or upgrade the design?
- Is your MX board consist of the following device? 1SM21BHU2F53E1VG
- Are you using the driver that comes with the AN881 example design?
- Do you have a chance to validate it on the CentOS 7.0 and see if there is any OS dependency?
- Could you please capture ltssmstate[5:0], currentspeed[1:0], lane_act[4:0] and link_up signal from Signaltap? This can help to confirm if the link training is up correctly.
Regards -SK
HSuh01
6 years agoThis is answers to your question.
- No. Are you referring scripts that comes in the form of zip archive? We updated IPs so that it can be matched with Quartus19.2
- Our device variant is 1SM21BHU2F53E2VGS1 not just E1VG. This is a ES variant.
- Yes. It is compiled currectly and loaded before we run any test. (We load the driver again if the host is restarted)
- No. I can try, but our IT policy allows us to use specific Linux distribution. We are using NFS system.
- I will get back to you once I got the signal tap results.
