CJohn56
7 years agoOpenCL 19.3 SD Card image for Intel Arria 10 Development Kit
Hi, I am having problems with creating my own SD Card image for the Intel Arria 10 Development Kit. I have tried the GSRD 19.1, but I cannot get the OpenCL Driver working. I have also tried genera...
MEIYAN_L_Intel
6 years agoHi,
May I know after you see this "ERROR (phandle_references): Reference to non-existent node or label "led_pio"", are you able to generate the dtb file?
If yes, then you can ignore these error, however "led_pio" component cannot be toggle by linux system driver.
For the second error mentioned, according to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_rte_getting_started.pdf with chapter 4.1.4, the steps should help overcome these issues. Can you applied with this?
For the last question: yes, the bsp-editor is no longer available in 19.3, you should refer to rocketboard on how to create uboot on 19.3, or you can used older version(Quartus Prime Pro 19.1v) in order to used the bsp-editor.
