TTetz1
7 years agoOn Stratix 10 GX, running PCI Express example, is it normal to see much lower DMA write throughput than read throughput with default options?
I'm running the intel_fpga_pcie_link_test software, following all the steps in the Avalon-MM Intel Stratix 10 Hard IP+ for PCI Express document. When running option 0 - Run DMA, I see about 13 GB/se...
SengKok_L_Intel
7 years agoI would suggest you to test the AN829, there is some data to benchmark the throughput of DMA, if based on the user guide above, it mainly is to test 100 write and read.
Regards -SK
