On Stratix 10 GX, running PCI Express example, is it normal to see much lower DMA write throughput than read throughput with default options?
I am referencing "Avalon-MM Intel Stratix 10 Hard IP+ for PCI Express Solutions User Guide", which has "UG-20170" near the bottom of the title page. The design is 16-lanes.
Some further information: On intial loading of the driver and running of the user example program "intel_fpga_pcie_link_test", as long as I turn off "Run Simultaneous" on the DMA options, then I see about 8 GB/sec write throughput. This is true even if "Run read" is on. It is true before or after running the "link test" option.
As soon as DMA option "Run Simultaneous" is on, write throughput drops to 0.49 GB/sec and stays there. It remains low even if "Run Simultaneous" is turned back off. It remains low even after doing an "unload" and "load" of the kernel driver.
Tom
