TTetz1
7 years agoOn Stratix 10 GX dev kit, the D3 error LED is red shortly after power up. Is this normal?
All DIP switches are configured as listed in the User Guide, UG-20046 (So, please don't just link the user guide again in response.) Running the dev kit in bench top mode. I've been unable to progr...
YuanLi_S_Intel
7 years agoHi Tom,
Yes it is completely normal. The device will try to configure again for several times if configuration fails. As long as the green LED (configuration done indicator) lights up in the end, it should be fine.
Can you try to change the TCK frequency of your USB Blaster II to 6MHz?
YL
TTetz1
7 years agoThanks. I did try 6MHz on USB Blaster II, as well as some even slower speeds. I still get synchronization errors. I'll try again on Monday to see if I can get anything at all programmed on the board.
