TTetz1
7 years agoOn Stratix 10 GX dev kit, the D3 error LED is red shortly after power up. Is this normal?
All DIP switches are configured as listed in the User Guide, UG-20046 (So, please don't just link the user guide again in response.) Running the dev kit in bench top mode. I've been unable to progr...
YuanLi_S_Intel
7 years agoHi Tom,
Red LED means that configuration is error. If it goes off, by right it shouldn't light up. What about the green LED? does it light up?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-s10-fpga-devl-kit.pdf (Page 9)
Can you show me the screenshot of error message that you got when you program the device.
YL
- TTetz17 years ago
Yes, I know the Error LED means configuration fails. The question is if it is normal for this to be red immediately after power on.
On the question of the green LED, if you mean D45, the power LED, then yes -- it lights up when the board is turned on, as expected.
Attached is the screenshot of the error message when I attempt to program the device . I also attached the message from jtagconfig, which shows that at least it is identified on the chain.
- TTetz17 years ago
hmm, I guess I can only attach one file per reply. Attached is the other file.
