FRava3
7 years agoOn Max10 the watchdog in "dual image configuration" doesn't work
I’m facing some problem in setting up the Max10 in dual-boot configuration. How our Max10 is configured: UFM0 – Boot fw (Nios) CFM1 – Boot hw CFM0 – Application hw Application fw(Nios) is on an ...
AnandRaj_S_Intel
7 years agoHi,
When using the Dual Boot IP, you should enable the CONFIG_SEL pin options to determine which image the MAX 10 need to be boot up. Then use the config_sel_overwrite bit and config_sel bit to switch between the image 0 and 1 without power cycle.
You can use the example design attached to compare with yours if there are any difference settings.
Reference
https://www.youtube.com/watch?v=0k4AZmdW9Sk
https://www.youtube.com/watch?v=Z0l0GrjXn8w
Anand
