christhian
1 year agoon DE1-SoC application fails to program but other works fine
Greetings to all (and sorry if I mess up somehow, first time posting to a forum like this) My issue is that I've been trying to program an FPGA DE1-SoC Cyclone V board using Quartus 17.0 with a proj...
sstrell
1 year agoSo you can successfully program the device with other .sof files from other projects?
If so, you may need to regenerate the system in Platform Designer and recompile the Quartus project to make a new programming file (.sof).
Also, check that System ID component in PD. You may want to try removing and re-adding it before regenerating the system.
