14 years agoOn-Chip Memory
Hi all, i have a question.What is the total memory size from the DE0-Nano Board? In the tutorials they always use 26000bytest but is that all?? I use the SOPC Builder. My problem is for the normal ...
14 years agoI agree with Bad Omen. The internal memory in the DE4-nano FPGA is 594 kbits. So the maximum usable TCM memory would be around 64 K bytes if you are lucky.
If you want to use the full C library, I would recommend starting from the Terasic Nios example that has the SDRAM controller in it. then going from there. Pete
