Gouri
2 years agoOn chip flash memory not updating avmm_data_readvalid signal in Read operation
https://www.intel.com/content/dam/altera-www/global/en_US/uploads/7/73/MAX10_On-Chip_Flash_IP_Read_Operation_Example.pdf With respect above document of read write operation in On chip flash UFM IP...
ShengN_altera
2 years agoHi Gouri Adsure,
Have you use the same setting like the original design On-Chip Flash IP check the screenshot attached?
I had used a new On-Chip Flash IP named flash_ip1 which is generated in VHDL and followed the same setting. Then instantiated that ip in top verilog module and compiled as mixed language. I'm able to see the same result on flash_ip1.
Attached the file for your reference.
Sheng
Gouri
2 years agoHello,
Thank you for your valuable time.
- Is there any On-Chip Flash IP setting difference for FPGA 10M16SCU169I7G.
- Is Any change in avmm_data_burstcount for above FPGA.
- Any other changes we need to do for this FPGA as per datasheet for read write operation.
Thank You
Gouri Adsure
