14 years agoOld PCI Development Kit Compatibility
Hi All, I'm working on a project that requires the PCI bus. I currently have a PC with an Altera license (Quartus II, ver. 10.0) that I purchased in 2010. But now that I'm starting on this n...
14 years ago --- Quote Start --- Thanks for the quick response. In the system I am developing the host PC (SBC) will be running on Windows 7. I plan to use WinDriver (Jungo) to implement the device drivers (the kit itself recommends this product). But I wasn't planning to install the kit software on this SBC because I figured Quartus II 4.0 (2005) was unlikely to be compatible with Windows 7 - and I wasn't thrilled with the idea of using Windows XP mode for development. Rather, I thought I would install this old kit software on a PC that I have running Windows XP. This is the same PC on which I already have a licensed Quartus II 10.0 installed. --- Quote End --- Yes, install the kit software under Windows XP, grab the files you need, and then start porting the design to a newer version of Quartus. --- Quote Start --- Have you tried installing and running old Quartus II versions on Windows 7? --- Quote End --- I have Quartus 11.0, 11.1sp1 and 11.1sp2 installed on Windows 7. Cheers, Dave
