CHaki
7 years agoNot seeing the JTAG scan chain on Cyclone 10LP
Here is my FPGA schematic and some screenshots of the programmer software. This is running on Windows 10. When I try to access the chip, the blue light on the USB Blaster goes on for about half a sec...
AnandRaj_S_Intel
7 years agoHi,
Check If another board working with the same setup(board, configuration, USB cable & power supply setup)? if yes.
We have to suspect board.
Check if the board is Power properly. Check POR from the Handbook
Check the pull-up resistors on the configuration side.
check for Solder Bridging, Lifted Components & Solder Skips.
Anand
