14 years agoNo Nios II target connection paths were located. Check connections and that a Nios I
Hello, I am new to Altera tools. I am trying to run through the BeMicro SDK Lab Instructions (November 2010, Version 10.0) and came up with the error: "no nios ii target connection paths were ...
14 years agoI looked at those and tried the command shell. When I try to use the "nios2-terminal" I get the following reply back in the command shell:
"There are no JTAG cables available on your system. However, when I go to my PC's Device Manager, "Altera USB-Blaster" shows up in the USB section. When I tell it to update the driver, it comes back and says: "The best driver software for your device is already installed". I have also tried re-installing the Quartus and Nios software as administrator---same result when it gets to this part of the lab.....
