ukuma8's avatar
ukuma8
7 years ago
no nios ii target connection.
eclipse is not detecting any target connection and i downloaded .sof file in FPGA. i pressed several times refersh connections but it is not detecting. in my design niosii,clk with 24mhz,on chip mem,jtag uart and pio.iam using quartus ii 13.1 ver in windows 8,cyclone iii fpga and USB blaster ii. please help..
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Hi Uday,
    Refresh connections after selecting the checkbox "Ignore mismatched system ID" and "Ignore mismatched system timestamp.
    under Run->run configuration->Nios ii harware->new_configuration->target connection tab-> and select Ignore mismatched system ID" and "Ignore mismatched system timestamp.
    Anan
  • ukuma8's avatar
    ukuma8
    Hi anand,
    thanku for ur reply.
    i had tried by ignoring the mismatched system id and timestap still not detecting any target connection.please help...
    AnandRaj_S_Intel
    Maybe .sof file not loaded or tool, before concluding
    Can you try using the example project?
    Anand
  • ukuma8's avatar
    ukuma8
    thanku for u reply.
    yes we followed example project and .sof file was loaded. I verified this by writing vhdl code (GPIO toggle with input clk 24mhz) in portmap file(top level entity) and compiled and loaded .sof file in FPGA it shows 100%. please help..
      AnandRaj_S_Intel
      ​Try using different Quartus version.
      Have you used example project???
      • ukuma8's avatar
        ukuma8
        please tell me quartus versions which supports cyclone iii family
  • ukuma8's avatar
    ukuma8
    i followed tutorials (introduction to qsys,my first nios tutorial etc.) Can u give any sample example project for cyclone iii which supports quartus 13.1?
    please help..
  • ukuma8's avatar
    ukuma8
    and also the USB Blater ii emulator supports our fpga cyclone iii(EP3C80U484I7)?
      AnandRaj_S_Intel
      ​Recreate the eclipse project with correct sopcinfo and check.
  • ukuma8's avatar
    ukuma8
    finally after doing above posibility iam going to install low ver Quartus ii (ver 12.1) with usb blaster ii emulator.
