14 years agoNios2 Stratix II Development Board Power Adapter
I have an older Nios2 development board that has a missing power adapter. I notice that the board denotes +-12V to +/- 18V and the documentation online that best resembles that board refers to a 17V...
14 years agoTake a photo of the board and post it. It'll be easier for people to recognize.
Do you have the schematic for the part. If its a well-designed schematic, it should have the maximum current required for the input supply, or at least the maximum current from each of the generated supplies. The other way to figure it out is to use a lab supply first, check things work, put in a power-consuming design, and then buy a fixed voltage supply that exceeds the measured numbers. Cheers, Dave
