18 years agoNios II Evaluation Kit Cyclone III Edition Usb Blaster Not Detected
Hey I am using NIOS II EVALUATION KIT CYCLONE III EDITION. the usb blaster is not recognised in both the flash programmer and the quartus programmer. The driver is installed. I am able to progra...
18 years agoThanks for the info.
I tried using the USB Blaster (stand-alone cable) cable on J4 (after shunting JP8) - it does detect a chain, but shows "unknown_20F30DD" under 'Device'. When i connect the usb, in the device manager it is recognised as 'USB High Speed Serial Converter', and the manufacturer is given as 'FTDI'. So i guess theres some configeration error. The clock appears properly at R42 and C35
