18 years agoNios II Evaluation Kit Cyclone III Edition Usb Blaster Not Detected
Hey I am using NIOS II EVALUATION KIT CYCLONE III EDITION. the usb blaster is not recognised in both the flash programmer and the quartus programmer. The driver is installed. I am able to progra...
18 years agoTo detect the Dev Kit hardware as USB Blaster, these conditions must be met, I think:
- The USB related hardware must be oprational and connected to USB - The board ust be powered and the EPM3128 have a configuration, that sources 6 MHz clock to FT245 - The 93C46 EEPROM must contain the correct configuration. Cases have been reported, where a Dev Kit lost the FT245 configuration and was detected as a USB to serial adapter instead - The driver must be installed So in addition to what you alredy did, you could check for unexpected serial adapter. If it is detected as such, it may be a lost configuration or a driver issue. You can also check, if a 6 MHz clock is present at R42 and C35.
