Olee01's avatar
Olee01
7 years ago
NIOS II cannot run from an external memory QSPI?
I've created the design based on this document but it is not working
https://www.eeweb.com/app-notes/download/169865
  • Hello.
    I would check the following items:
    1- Make sure Nios II reset vector and exception vector are both pointing to QSPI
    2- Make sure you use 25MHZ clock as maximum to the QSPI IP.
    3- Try to use PLL for your system clocking. One clock would be for the system.
    Please let me know if any of the debug steps would help.
  • FawazJ_Altera's avatar
    FawazJ_Altera
    Hello.
  • Olee01's avatar
    Olee01
    I was using external clock for the Qspi block once I used the PLL it is working now.
