Olee01
7 years agoNIOS II cannot run from an external memory QSPI?
I've created the design based on this document but it is not working https://www.eeweb.com/app-notes/download/169865
- 7 years ago
Hello.
I would check the following items:
1- Make sure Nios II reset vector and exception vector are both pointing to QSPI
2- Make sure you use 25MHZ clock as maximum to the QSPI IP.
3- Try to use PLL for your system clocking. One clock would be for the system.
Please let me know if any of the debug steps would help.
Olee01
7 years agoI was using external clock for the Qspi block once I used the PLL it is working now.
