8 years agoNEEK Cyclone III edition programming
Hello, I´m new to Altera and I´m using Nios II Embedded Evaluation Kit (NEEK), Cyclone III Edition. My first question is: Do I need any programming device betweeen PC and NEEK? I tried co...
8 years agoHi,
thank you for support, driver is instalation was sucesfully. I had to manually show the driver a path to the driver. But one error is still persists.. When I open Eclipse, click on New, than Nios II Application and BSP from Template, in window choose file.sopcinfo and click on finish, there is error "./create-this-bsp --cpu-name cpu --no-make". It is the same on version 13.1 and alsoo 12.1. I´m using Windows 10, isn´t it problem?
