16 years ago
Need help running the PCIe to DD3 Reference design program in Windows7 or Vista
I got the Altera PCIe to DD3R reference design program (http://www.altera.com/support/refdesigns/ip/interface/ref-pciexpress-ddr3-sdram.html) to work successfully in Windows XP, but now I'm trying to get it to work on two other machines with Windows Vista and Windows 7 OS? The Jungo drives for the reference design will not install correctly in either Vista or Windows 7. Is there a way to get around this? Has anyone out there got this reference design to run on Linux? Has anyone out there written a driver to run this program on either of these other operating systems?
--- Addendum ---
See the screenshot ... you can see that when I run the install.bat, I get an error (unsupported operating system).
Is there any way I can get wdreg for Windows Vista ... is there any way to make this work in Vista?
Eric
Electronics Engineer
Microwave and Communication Systems Branch
NASA Goddard Space Flight Center, Code 567
8800 Greenbelt Road, Greenbelt, Maryland 20771, USA
Building 25, Room S054, Mail Code 567.3
Phone: (301)-286-3439 Email: [email protected]
    Hi
    I am trying to run the reference design on Arria II GX development board but having the same issue as you are having. There are no Windows XP machines available in the market with PCI Express cards. I have a Windows 7 machine with PCI Express card. Did you find any work around to this problem?
    Raj
    408-750-4359 (Mobile)
    I am in the same position.
    I have gone so far as to install Windows Virtual PC with XP Mode. This will install the drivers, but cannot see the hardware, while the Windows 7 host OS can see the hardware, but won't install the drivers.
    I have searched and searched the Altera site, Forums and Wiki, but I have found nothing useful, just this thread. Does anyone know if there is a Win 7 compatible version of the driver and GUI, or if there is some configuration needed for the Virtual PC to see the PCIe hardware?
    Cheers,
