Need help in developing logic!
People in Intel community are not here for code for you or implement your project for you so please come with project consisting of HDL coding or *bdf files with appropriate logic that helps to user in community to narrow down your issue or address your issue with proper solution.
Vicky
Thanks for your suggestions. I am not asking anyone to write code for me. See my subject again and just signal detection can’t be someone’s entire project.
BTW, I had posted this same question on another forum and got a suggestion to ‘implement detector of the rising edge for the sync signal. You could implement counter (startingelectronics dot org/software/VHDL-CPLD-course/tut19-up-down-counter/ ) which would increment every rising edge of SYNC and on every time pulse (say 1ms using m clock), you would check if the counter changed.’
I have implement the logic, below is the code. But it is working only first time connection of sensor. When I disconnect the SYNC signal the output doesn’t goes to low. Please advice the changes, I am beginner in VHDL and not an expert.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity sync_detector is
Port ( SYNC : in STD_LOGIC; -- Input SYNC signal
PULSE : in STD_LOGIC; -- Input 1.024ms pulse
OUTPUT : out bit -- tells SYNC status
end sync_detector;
architecture Behavioral of sync_detector is
signal S0_s : std_logic := '1';
signal counter_running : std_logic := '0';
signal count : STD_LOGIC_VECTOR (3 downto 0):= X"0";
begin
S0_s <= not(SYNC);
-- Process for 4-bit counter
process(S0_s)
begin
if (S0_s'event and S0_s= '1') then
count <= count + '1';
counter_running <= '1';
end if;
end process;
-- Process to check counter running after each 1.024ms
process(PULSE)
begin
if (PULSE'event and PULSE = '1') then
if counter_running = '1' then
OUTPUT <= '1';
else
OUTPUT <= '0';
end if;
end if;
end process;
end Behavioral;
- Vicky16 years ago
Please ensure the counter is running or not by tracing the 'count' signal in waveform window.
Vicky
