16 years ago
Need help creating a simple 32bit counter
I'm trying to learn VHDL so I thought I'd try converting the "my_first_fpga" example from verilog to VHDL (how complicated can adding one to a number be?), three hours later, lots of googling and searching through books has yielded no result. Sorry if this is the wrong place to ask (if so where is a better place?)
So I run this code through the simulator, apply a 50Mhz clock to CLK and get nothing from the counter bus. to make sure the process is running I output CLK to OUT, if I hard code a value ie X"FFFF0000" to counter it outputs that value but counter := counter +1 gets me no where.
Also is it possible to step through code as with C?
Here is my code:
-- import std_logic from the IEEE library
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
-- this is the entity
entity counter_example is
   port (
         CLK : in std_logic;
         OUT1: out std_logic;
         Q    : out std_logic_vector(31 downto 0));
end counter_example;
architecture counter_code of counter_example is
begin
  process (CLK)
    variable counter : std_logic_vector(31 downto 0);
  begin
    counter := counter + 1;
    OUT1 <= CLK;  -- Sanity Check that I am actually outputting something
    Q <= counter;
  end process;
end counter_code;
    Your process that generates the clock is also triggered by the clock, which won't work. It's a bit like the chicken-and-egg problem ;)
    You should have two processes, one to generate the clock, and another one that triggers on it:
      Clockgen: process
      begin
        clock <= not clock after 10 ns; --will give 50MHz clock
      end process;
      Sim: process (clock)
      begin
        if rising_edge(clock) then
            counter_out <= counter_out + 1;
        end if;
      end process;
    It is also a good idea to add a reset signal to give your counter (and clock) an initial value. If you don't do that counter_out will start with UUUUU (uninitialised) in the simulator and will become XXXXX (unknown) at the first clock cycle.
    --- Quote Start ---
      Clockgen: process
      begin
      end process;
    --- Quote End ---
    This does not have to be inside a process, as it is a simple 1 line statement.
    Also, remember do not put this kind of code in your synthesisable code. Keep them separate as a testbench and a counter. If you put this code in and tried to synthesise it you'll some odd things getting generated.
    Yes, I mixed up with the way I usually do a clock, which is either
    Clockgen: process
      begin
        wait for 10ns;
        clock <= not clock;
      end process;
    or
    Clockgen: process
      begin
        clock <= '0';
        wait for 10ns;
        clock <= '1';
        wait for 10ns;
      end process;
    The latter is longer but doesn't require to initialize the clock value
