ARG007
1 year agoNeed guidance on Debugger Selections Criteria
I am looking for a USB Blaster that is compatible with Altera MAX CPLDs and would appreciate some guidance on which one to choose. Specifically, I am considering:
- Terasic USB Blaster
- Wave Share USB Blaster (Rewritten version)
Note: I have encountered issues with the cheaper version of the USB Blaster, as it never worked properly.
1 Reply
- Farabi_Altera
Terasic is Altera partner. They provide good USB Blaster cables.
You need to mention which MAX device you want to use.
MAX II? MAX V? - these are older devices, you can use USB Blaster 1 programming cable.
MAX10? - this is current device. you can use USB Blaster 1 or USB Blaster II programming cable.
regards,
Farabi
