N3000-2 XL710 or XVV710?
1) Thanks for the feedback. I have filed to confirm and correct on this issue.
2) Based on below spec:
Both XL710 and XXV710 does not support RDMA
In the newest PV1.1, in lspci, there is no mention of the variant to avoid confusion.
The datasheet naming remains XL710.
If you still seeing this issue despite having the latest Acceleration Stack + drivers installed.
Can you share with me the i40e and NVM firmware driver versions? Run "ethtool -i <linkname>"
For linkname, you can get by running "lshw -c network -businfo"...look at the corresponding linkname to the BDF of the Ethernet controller.
- ahaa5 years ago
Here are the version of i40e and firmware
- JonWay_altera5 years ago
1) Which acceleration stack are you using? "rpm -qa | grep opae"
2) How about if you switch to the factory boot image? "rsu fpga -f".....do you see the naming XXV710?
Also, please capture "fpgainfo fme" "fpgainfo port"
3) What is your OS/kernel version?
"cat /etc/*elease"
"uname -r"
- ahaa5 years ago
Here are the captures, thanks!
