Deshi_Intel
4 years agoHi,
Accordingly to PCIe user guide doc, you need to perform below 2 steps
- Turn on "Export MSI/MSI-X conduit interfaces" setting in PCIe IP to enable internal MSI interface bus
- Then create your own custom interrupt handler design to manage it
You can refer to page 99, chapter 8.3. Interrupts for Endpoints Using the Avalon-MM Interface with Multiple MSI/MSI-X Support of the user guide doc
dlim
OlegT
4 years agoThis is true, if we are takng about FPGA side of the question.
But I am asking about driver side. As I understand, the allocation of irq vector should not be dependant on whether custom interrupt handler is realized in FPGA or not.
Isn't it?
Who is ressponsible to set bits [6 : 4] (multiply message enable) of conrol register (0x50) ?
Thank you.
