14 years agoMulti-Touch LCD Help
Hey guys, I am working on a student project that uses the DE2-70 and the Terasic multi-touch LCD module. I am coding in Verilog on Quartus and am designing a touchscreen music synthesizer. Te...
14 years agocan you check the pin assignment is correct all? I think you can debug it using signal tap II to clear which pin's pin assignment is not correct, and you should note the I/O stand for GPIO pins should be 3.3v.
