AStoc3
7 years agoMTBF of FPGA, CYCLONE 10GX, 220LE, SPEED 5, IND TEMP, FBGA780
Hi Just wondering if anyone can help me with the MTBF of the item listed above
ChiaLing_T_Intel
Contributor
7 years agoHi Andre,
To know the MTBF or Failure-in-time rate (FIT), you may refer to the following solution:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd04072012_59.html
You can find the FIT rate for Altera devices in the Reliability Report. Kindly be noted that the FIT rate for devices within the same family with the same process technology will be very similar and can be used for devices not explicitly listed in the Reliability Report.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rr/rr.pdf
Thank you
Chia Ling
