MSI with avalonMM-DMA ip
- 5 years ago
I could not find the part that you have mentioned in the document. May I know which document you are referring to?
According to the PCI Local Bus Specification 2.3,
"If the Multiple Message Enable field (bits 6-4 of the Message Control register) is non-zero, the device is permitted to modify the low order bits of the message data to generate multiple messages."
KhaiY
KhaiY
- OlegT5 years ago
Thank you,
We are talking about same things.
