OlegT
5 years agoMSI interrupt in PCIe-MM-DMA example
Hello.
I am working with C10GX developement kit. As a starting point I use AN829 - Avalon-MM DMA ref design.
DMA works well. I want to test MSI in that design.
The design contains linux driver...
- 5 years ago
I've replaced legacy pci_enable_msi() with pci_alloc_irq_vectors(). Now ISR for single interrupts is called.
KhaiChein_Y_Intel
5 years agoHi,
Do you see the MSI when all the DMA data transfers are complete?
KhaiY
OlegT
5 years agoI do not see interrupt on host PC, but I see, that wr_dcm_master sends irq_data and irq_address to txs.
irq_data and irq_address are the values from MSIIntfc_o.
