JW1121
7 years ago[Modelsim AE]Fail to access fiftyfivenm_ver
Hi, An error would be found and here is my step. Run simulation with Modelsim ASE,no errors found. Migrating from Modelsim ASE to Modelsim AE,run simulation. The error message is listed. ** Er...
CalvinJoaz_P_Intel
Contributor
7 years agoHi Jamie,
To simulate designs with instantiated behavioral or timing primitives, ModelSim requires the libraries are referenced in the "modelsim.ini".
Kindly check the previous thread with similar issue below.
https://forums.intel.com/s/question/0D50P00003yyR0pSAE/error-about-library-path-of-simulation-waveform-editor?language=en_US
Thank you.
