ZhiqiangLiang
1 year agoMemory size in Cyclone 10 LP 10CL120YF484
Hi, I was told that the memory size in Cyclone 10 LP 10CL120YF484 is 540KB in this link:https://community.intel.com/t5/Nios-V-II-Embedded-Design-Suite/Configure-NIOS-firmware-burning-interface/td-p/...
tehjingy_Altera
1 year agoHi
If you are running the Nios on place in the on chip memory size.
In the Platform Designer, the on chip memory size is adjustable and its maximum size is dependable on the design you have in hand.
To answer the question of 1,2&3, you could set a size that is slightly bigger than the size generated. In your case you could set the on chip memory size to be 300KB.
When you generate the hex file using the script in Eclipse, if it could not fit into the on chip memory, it will generate an error.
What kind of statistic tool that you are looking at? Do you have an example?
Jingyang,Teh
