Measuring power consumption of MAX10 Eval Board
I presume this is the schematic for your board:
I don't know what you want to look at, but shouldn't that tell you what you need?
And if you need the PCB layout, it's here with the other documents for this kit:
- ch_briand5 years ago
Thank you for the help, but actually this is not my board. What you're talking about is the Development Kit, and I'm working on the Evaluation Kit (Intel MAX 10 FPGA 10M50 Evaluation Kit).
I have the schematic for my board: MAX10_10M50_EVAL_A1_2 (intel.com)I want to compare several boards and find the most energy efficient one. To obtain the power consumption, I need to measure a voltage and a current. The User Guide of the board says that I should be able to measure VCC_CORE (not explaining how though).
What I don't understand is how I can measure both of these values (especially the current) if the only way to access the circuit is those test pads?
- sstrell5 years ago
If you need that level of power measurement, in the past I'd lift pins and put in wire coils. For overall power use, you of course would put an ammeter on the power going in.
I don't know what that bullet point is trying to say, but you still need to use traditional methods for power measurement.
You could also use the Power Analyzer in Quartus if you've created a test design.
I'm afraid I can't lift pins as you propose, and I also don't want to measure the whole board consumption, only the consumption of the FPGA.
Thank you for your help but even if I wanted to lift pins, since I have no information on what current or voltage to measure, I wouldn't know for sure that I'd be measuring the right thing. I'm starting to believe that the bullet point was an unfortunate copy-paste from the Dev Kit documentation.Could someone from Intel give me more information about it or admit that this board isn't made for power consumption measurement?
