MHASI2
6 years agoMAX10 Single Supply and Dual Supply Differences
Hello, This is Hasif. I would like to know what are the differences between MAX10 Single Supply and Dual Supply definition. Looking forward for the reply. Thank you, Hasif
SreekumarR_G_Intel
6 years agoSingle power supply devices do have internal regulator ; which means externally(board level) you have to design one power supply. But tradeoff here is single power supply is meant forless performance compare to dual.
Whereas dual power supply requires two power supply externally connect to the device.
Here is the power management userguide link, can you refer the same ?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_pwr.pdf
