18 years agoMAX II Dev. kit programming
I enconter a strage phenomena: when I try to program the EPM1270F256CS5 I imediatly get an error: "Error: Operation failed" (the progarming is not started at all). This accures with every file I try even with the simplest design (direct connection from an input to an output). Moreover, I even can't erase the chip. I have tried with Quartus 6.1 and 7.2. However, if I use a blank file name (by auto detect), I am able to erase. Also, I have no problem of programming with the original pof files. Obviously, the progarmer is fine and I have some flaw in the file but I can't figure it out - everything during the compilation works fine. Probably will turn out as a stupid mistake. Any ideas?
