18 years agoMAX II Dev. kit programming
Hi, I enconter a strage phenomena: when I try to program the EPM1270F256CS5 I imediatly get an error: "Error: Operation failed" (the progarming is not started at all). This accures with every f...
16 years agoHi,
I faced a similar problem with the same Max II 1270 dev kit with ES device. I followed wahilakn's comment and modified the .qsf file by adding "ES"
set_global_assignment -name DEVICE EPM1270F256C5ES
but I was getting another error, this time from the Fitter(Place and Route):
Error: The supply voltage value 3.3V applied to the 'VCCINT' power rail is illegal for the currently selected device.
which was not a hardware issue, since the device is rated for both 2.5V and 3.3V by jumper J9 setting. So I had to comment out this line:
# set_global_assignment -name POWER_EXT_SUPPLY_VOLTAGE_TO_REGULATOR 3.3V
I am able to program the device after this modification.
