CWP's avatar
CWP
5 years ago
Max 10 FPGA Dev Kit JTAG issues
Hi, I was setting up a newly bought Max 10 Development Kit and installed Quartus Prime Lite Ver 20 on Windows 7 pc. I connect the kit's J12 via the USB cable provided to PC and upon power up the kit, the driver for the USB-BlasterII starts to install and shows no problem. A error message pop up when I ran the Board System Test (BTS) exe, stating "No JTAG cable is detected or selected" (see attach pic below). I then ran Quartus Prime's JTAG Chain Debugger and shows "TCK and TMS connection issue" (see attach pic below). Can I confirm there is an issue with the kit? or is there other setup I need to perform?
  • sstrell's avatar
    sstrell
    Open the Quartus Programmer and see if the device is detected there.
    I'm not sure if that recent version of Quartus will work OK with Windows 7.
  • CWP's avatar
    CWP
    Hi sstrell, thanks for the reply.
    Using Programmer, I had to select "USB-BlasterII" at Hardware Setting and after that, clicking "Auto Detect" a message pop out "Unable to scan device chain. Can't scan JTAG chain. Do you want to open the JTAG Chain Debugger to troubleshoot the JTAG chain?" (see attached pic) I tried using the Debugger and it shows "Error: The TCK and TMS connections...might have problem" (see attached pic)
  • We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
    • CWP's avatar
      CWP
      Issue resolved. It was the Microtronix's HSMC daughter board causing the JTAG chain issue. After removing this board, JTAG issue solved. Thanks for the support.
