too_chappy
1 year agoMAX 10 Eval Kit (10M08S) .POF not loading after programmed
Hi! I am using the MAX 10M08S evaluation kit from Altera. I can program the .sof just fine. I can program the .pof with NO errors and I can also verify the .pof is correct. 100% success. I am usi...
too_chappy
1 year agoI think we can close this issue because I solved the problem by just buying a new board. As for the fuse on the Max10, I will create a new issue.
Thank you so much for your help and support!
